Hello, I’ve got my first eBike, Aventon Pace 500.
My bike has 8 speed gear set.
I’m trying to understand the relation between gearing & battery life/top speed.
(Confusing than I initially thought when motor comes into play.
To be as simple as possible, let’s assume I use throttle all the time. So my top speed is fixed at 20mph.
Q1. Which gear should I use to have maximum drive range? (Using battery efficiently)
- High gear (8, the biggest one, closest one from the frame)
or
- Low gear (1, the smallest one, farthest one from the frame)
For example, if I use low gear, I’d accelerate faster but this would use more battery, especially during hill climb.
In contrast, if I use high gear, the acceleration would be slower than lower gears but since motor uses less power to crank, my range would be maximized. - less resistance to motor whether I’m on flat, incline or decline
Is this correct?
I will have the same top speed. And acceleration is not my concern. (It’s not like motorcycle so I can just start from high gear.) My goal is to have maximum range.
Q2. My bike manual says it can go faster than 20mph when I do pedaling. How can I achieve this?
- PAS 5 (Highest level of pedal assist) + Lowest Gear? All the time
or
- Somewhat different? (Like PAS 3 + one of low gears depending on situation?)
What’d be optimum combination?
When I watch video, some eBike commuters seem to only use the lowest gear and don’t shift it. I guess this’d be fastest way to get around with the best acceleration. But I think this would consume battery quickly because the lowest gear requires the most power from the motor.
I’m curious how others ride eBikes usually.
(or... just putting in the middle and forget about it?
Thank you.
or
Is this correct?
or
Thank you.
