What are your plans for this bike? Why the 2000w power? Is this a direct drive or a gear drive? Hub mount or mid?
I'm asking as generally people would buy 2000w of power for fairly high performance. Issue here being running that on a 15 amp battery. The battery will be OK, assuming it's wired heavily enough to have 2000w (35a) pulled from it, but with that kind of draw, your range is not going to be good. Yes, you can probably get 15 miles out of it, but you're going to have to be pretty conservative supplying a lot of power yourself.
