Mtl_Biker
(I posted a message about this in the general section over an hour ago and now the message is gone. Strange! Anyway, I'm now posting my question here.)
I got my new bike yesterday and neither of the two manuals that came with it say anything about the front air suspension... how it works, how to adjust it, etc. So I'm asking you folks for help...
When I first got on the bike the front suspension sort of did a little hop and then just felt mushy (I don't know how else to describe it). I'm used to oil suspension (on my Specialized Stumpjumper XC Comp FSR) and this behaves nothing at all like it. There is a lever on top of the right fork that can be turned to a "lock" position. I did that and the bike was much better. I guess that makes the bike act as if there is no suspension. But I'd really like to know what adjustments to make.
The top of the left fork has a cap marked "air" and under it is a Schrader valve. It looks like a regular car air valve. What should I do? How much pressure should there be? Am I right that more pressure would result in a firmer suspension? I'm bummed that there isn't any info about this in the manual. I have a high-pressure Blackburn pump that works with Presta or Schrader valves but it doesn't fit deep (low) enough on the valve to be used here. What kind of pump is needed for this?
Under what conditions would you use lock versus air? Is it just personal preference?
Any help appreciated!
