So I crashed my bike and had to replace the front fork. I got a new fork and installed it, but wasn't able to ride due to bad weather until today. When I put the disc brakes back on I noticed the bottom of the two screws that holds the brakes in place wouldn't tighten all the way. It goes most of the way, but before getting tight it reaches a point where it just kind of turns in place. I didn't notice a problem just lifting the front wheel and spinning it, but today I tried to go for an actual ride and shortly into it the brake pads started rubbing on the disc a lot.
Since the problem doesn't happen when I just spin the wheel I don't believe my brake rotor is bent? I believe despite the brakes not feeling loose when I try and move them with my finger the screw not being tight is the source of my problem (hit a bump and brakes are knocked out alignment)?
I tried two screws which both work fine on the old fork. This means the new fork arrived with the hole stripped? I contacted the seller, but assuming they don't send me a replacement how could I go about fixing this? Thanks.
