e-Glide SS Plus for sale (Marin - North of San Francisco) $850
at685
Selling a lightly used eGlide SS Plus (every option added)
Never used in the rain and has about 20 battery cycles (good for 800 so years left). I've used it a handful of times in the past year. In great shape. New computer (I have the old one also which works but I had every intention of using the bike more this year).
GREAT looking bike (matte black) and extremely fun to ride. Very light for an eBike and just a ton of fun. I highly recommend looking on their website as well as looking at all the five star reviews.
Throttle plus single speed pedal assist. 20mph and around 35 miles range.
Better pics to come...
Some details:
The Battery
A 36 volt, 10.4 amphour lithium battery, made with quality Samsung cells, is rated for 800 charge cycles. The lithium battery will provide a 20 plus mile range, on flats, under throttle power only. Range is up to 40 miles in pedal assist mode. The battery locks to the frame, can be removed in seconds, and can be charged on or off the bike.
Motor
The 36 volt brushless, geared, hub motor, is rated at 350 watts nominal, 700 watts peak. It will power the bike to 20mph in seconds without pedaling. You can easily exceed 20mph by pedaling.
Seat
Handmade in Italy - Selle Royal has been making saddles in Italy since 1956, trust in their 60+ year heritage of making the world's most comfortable saddles. Their Respiro gel saddle is one of the most popular seats in the industry, and is built to last many years
Throttle
The SS is equipped with a thumb throttle.. Power without pedaling by using throttle only, or utilize one of five power settings for power assist. The throttle operates independently of the pedal assist system, and will provide full power on demand, instantly.
Tires
The German Marathon Plus tire is the best selling bicycle tire in Europe, and is absolutely the best tire for the SS. Why? It has a special Kevlar liner, and is considered to be the most flat free tire produced by anyone. The tire also offers fantastic handling, shock absorption, and just feels great.
Make E-Glide Plus
Model SS
List Price $1,699.00
Body Position Upright
Suggested Use Urban, Commuting, Neighborhood
Electric Bike Class Throttle on Demand (Class 2)
Total Weight 41.5 lbs (18.82kg)
Battery Weight 5.5 lbs (2.49kg)
Motor Weight 6.5 lbs (2.49 kg)
Frame Types High-Step, Mid-Step
Frame Sizes 21 in (53.34 cm)
Geometry Measurements 21" Seat Tube, 21" Reach, 30.5 Stand Over on High Step and 29" on Mid-Step, 67" Length
Frame Material 6061 Aluminum Alloy
Frame Colors Matte Black
Frame Fork Details Rigid Steel, 11 mm Quick Release Skewer
Frame Rear Details 11 mm Steel with Bolts
Cranks Aluminum Alloy Cranks, 44T Chainring (Optional 48T Chainring)
Pedals Wellgo Plastic Platform
Headset Neco Sealed, 1-1/8
Stem Promax, 8 degree Angle, 80 mm Length
Handlebar Aluminum Alloy, Mid-Rise, 25 mm Diameter, 23" Length, 80 mm Rise
Brake Details Shimano Mechanical Disc with 160 mm Tektro Rotor in Front, Promax Linear in Rear, DE1 Levers with Motor Inhibitor
Grips Generic Ergonomic, Rubber
Saddle Italian Selle Royale Respiro Gel Saddle
Seat Post Promax, Aluminum
Seat Post Diameter 27.2
Rims Alloy Mid-Dish, Black
Spokes 13 Gauge Stainless Steel, Black
Tire Brand Schwalbe Plus, 28" x 1.25"
Tire Details Reflective Sidewall Stripe, Performance Line SmartGuard
Tube Details Presta Valve
Accessories Rear Carry Rack
Other Locking Removable Battery Pack, 1.5 lb 2 Amp Charger
Motor Brand Henti
Motor Type Rear-Mounted Geared Hub
Motor nominal Output 350 watts
Motor Peak Output 700 watts
Battery Brand Samsung
Battery Voltage 36 volts
Battery Amp Hours 10.4 ah
Battery Watt Hours 374.4 wh
Battery Chemistry Lithium-Ion
Charge Time 5 hours
Estimated Min Range 18 Miles (29 km)
Estimated Max Range 35 Miles (56 km)
Readouts Battery Charge Level (4 dots), Assist Level (Low,Med, High)
Display Type Fixed LED Control Console, Removable MUCH MB1 Monochrome Bicycle Computer (Speed, Time, Trip Time, Odometer, Trip Distance, Max Speed, Avg. Speed)
Drive Mode Cadence Sensing Pedal Assist, Trigger Throttle (12 Magnet Cadence Sensor)
Top Speed 20 Mph (32 kph)
Selling because I don't really use it as much as I hoped and don't have the room. I did ride it this week and it is great fun but I use my mountain bike more because I can use the trailer for my kid. Ideally local - ore down to finding the time to ship it... I will recommend the e-Glide though - whether you are interested in mine or not. I tried several bikes and this was just great - look cool, rides great and I do like the mix of thumb accelerator and pedal assist. Plus Dave - the guy who produces these - was great to deal with when I bought it.
Pics added - I'm very sorry for those who contacted me - I was away for a couple of weeks unexpectedly
