Yes, 3a @ 110 in certainly isn't the same as 3a @ 42v out, but that's what's printed on the charger label. Then Giant comes along and calls this one a '4a charger'. LOL
Their 'smart charger' is 6a, I'll have to look at the label on that one.
So I wasn't that far off, but not sure why the calculator I found said 30ah. Anyway, a solar setup would surely be nicer to live with than a generator - was discussed on another thread, and there are certainly some detractors for anything that runs on gas. I get it, and a good one is expensive as well, I think the little honda one is a grand.
I do have interest in sorting this out since we would like to take ebikes in the RV and there aren't always plug-ins, or at least it would be nice to be able to park in a casino lot or something on the road and still be able to charge them. IMO $1500 is too much for a remote charging setup. If the numbers above are realistic then it could be done for about a third of that.
The company that was selling the 'suitcase' solar panels seems to have closed. At least I can't find them anymore. But they are easy to make, and a basic pwm controller is really cheap and okay for this application, when using 18v max-output panels. My two 80's folded are 2x4 feet, about 2" thick, and slide into a storage compartment in the RV. Initially I had looked at roof mount systems, but there were so many advantages for the portable that I went that way instead. We don't use them very often, but when needed are really slick. We used to have to run the genny every day to stay charged, but this obviates the need to do that, unless you need air conditioning - then all bets are off.
The built-in Onan is 4kw, drives a 15Kbtu ducted roof AC. Even then those are only good for about a 25deg drop in interior temp, which is fine when it's a hundred or less, but gets warm for really high ambient temps, like the dez, or AZ over summer. We'll even run it motoring down the hiway as the dash-air can't keep up.
