6zfshdb
- USA
- City
- Northeast Pennsylvania
I posted this in another thread but decided to place it here as well since it pertains to Pedego batteries.
A simple rig can be built, using these parts, to discharge Pedego 36 & 48V batteries for long term storage.
Four medium base (E26) bulb sockets
A 12 hour timer
Four of these bulbs:
I cut the plug of a cheap extension cord in half. The flat spades fit perfectly into the main power connector on the Pedego battery. The polarity does not matter.
By using the main battery connector instead of the XLR charging port, I was able to take advantage of the battery's built in power switch and fuse.
The rig can be used & stored flat on a bench or hanging on a wall.
All four bulbs draw just under 1 amp. Bulbs can be added or removed to adjust the draw. In theory, all four will fully discharge a 48V, 15AH Pedego battery in a little over 15 hours. A test showed the rig reduces a fully charged battery to 80% in about 4 hours.
The total cost of the rig is just under $60. It has other uses though. It provides the equivalent amount of light as four 60 watt bulbs for up to 15 hours. In addition to using it during a power outage, I've also used it as a portable light source when working outdoors.
A 12 hour timer
