SI Symbols (International System of Units)…
Here are a few comments on writing SI symbols – mainly relating to the use of upper or lower case. I hope the explanation will be both informative and interesting, especially if you live in a country that hasn’t adopted SI units.
- When a unit of measurement (amp, newton, volt, watt - written in lower case) takes its name from a person (Ampère, Newton, Volta, Watt), its SI symbol is written in upper case (A, N, V, W).
- The symbols for other units (gram, metre, second) are written in lower case (g, m, s). Local variations are permitted; for example, litre can be spelled liter or given an upper case symbol L (to avoid confusion with 1).
- Symbols are never followed by a period (except at the end of a sentence) or have an s (the symbol for second!) appended to make them into plurals.
- Most units can take a prefix to indicate a mulitple (k for kilo – thousand; M for mega – million) or a fraction (m for milli – thousandth; n for nano – billionth).
Some examples to use in the EBR Forum:
- m : metre (one of the seven base units)
- km : metre with the prefix k for one thousand
- km/h : kilometres per hour (always use a slash not a p for ‘per’)
- mm : millimetre; metre with the prefix m for one-thousandth
- Ah : amp hour **
- Wh : watt hour **
- Nm : newton metre **
- (** In maths equations separate the letters with a centre-dot or a space.)
- nm : nanometre; one-billionth of a metre (eminently appropriate for heated discussions about preposterously insignificant variations in tyre circumferences).
Wikipedia : International System or Units
… David
