Deleted
rich c Well-Known Member Dec 14, 2022 #2 Replace it, if it really is the clutch on the planetary carrier. Did you check the freewheel?
rich c Well-Known Member Dec 14, 2022 #3 mrcushman said: Do you mean replace the clutch or the motor? Is there no other fix? Click to expand... Replace the sprag clutch. If you have a geared hub motor and the freewheel on the gear set is okay.
PedalUma Well-Known Member Region USA City Petaluma, CA Dec 14, 2022 #4 Did you check the kickstand? Many bikes don't roll backwards when it is down. It is a common complaint.
PedalUma Well-Known Member Region USA City Petaluma, CA Dec 14, 2022 #5 So you know, I was joking. You are taking the right steps. Have fun with my posts too. We need some humor given the tough stuff.
