Crank Arm/ Pedal Repair
erider_61
So I tried using JB Weld to repair my stripped crank arms but that only lasted a few days before the pedals fell off. So I ordered a crank puller and removed the cranks and drilled and tapped both pedal spindles.
JB Welded the pedals back on and then installed stainless hex bolt with 2 flat and 1 lock washer. Hoping this will hold until I can order some new crank arms and pedals.
