Hiya.
I have a bike with a Bosch Performance Line CX with Intuvia display.
I have the latest firmware as at Feb 2018 with eMTB mode.
I also have the latest small version of the Speedbox 2 tuning module installed.
Everything was running fine although my top speed was making out at about 40-45km/h but with crazy fast pedalling.
I decided to pop on a new Bosch 18T front sprocket. Took it for a ride and noticed the Speedo running up and down, not stable at all. The speeds of 40-60 Km/h are now possible with this gearing, I recorded a top speed of 58 km/h on that short test run. Keeping up with inner city traffic is now a lot easier. You certainly get more of a workout on the bike with the 18T, that is good, I was getting too soft with the 15T. I will need to either add some links or replace the chain but it is rideable at the moment.
As I got closer to home it started to cut then bring back power as I was pedalling up a hill.
So, does anyone know if the Bosch motor setup needs to be configured for an 18T by a Bosch dealer? Or do I have some other issue?
Cheers
Cheers
