Cannondale VS Trek -- These E-Bikes are almost the same?
zipur
I'm a happy Trek Allant+ 7s owner, It's interesting how these two manufacturers' products line up. I know there are the RADs, Pedego & others out there, but I limited it to what's near me and frankly, Pedego bikes do not appeal to me. If you're researching bikes, this is good to know information.
You have to judge for yourself, weighing the manufacturer history, support, fit, style, price, and features.
Why did I get an Allant+ 7s? It came down to the looks, fit me just right, and what the Local Bike Stores had available. In my area, many of the Local Bike Store's are becoming Trek Bike Flagship Stores. They are saturating the market with locations everywhere. Is that true nationwide? Is that because of Covid? Sure there is there two Pedego stores within 20 miles and a couple of REI stores selling Cannondale. But there are eight Trek Bikes Stores in the same 20-mile radius area. That was a big selling point for me here in the Dallas Fortworth area, YMMV.
I am no expert, so maybe some of you more experienced members can point out Which Equipment is better between the two.
The Trek bike that matches up most closely with the Cannondale Topstone Neo Carbon 2 is the Trek Domane+ HP
TREK E-BIKES
ModelAllant+ 8S Stagger
Allant+ 8S Stagger
highlight_offRemove
Domane+ LT
Domane+ LT
highlight_offRemove
Verve+ 3 Lowstep
Verve+ 3 Lowstep
highlight_offRemove
Allant+ 7S
Allant+ 7S
highlight_offRemove
Price$4,399.99$5,499.99 - $5,999.99$3,249.99$3,999.99
Model number30266309153098031929
Bike model year2021202120212021
Colors available
Rating
16 Reviews
19 Reviews
23 Reviews
85 Reviews
DescriptionAllant+ 8S Stagger is a performance e-bike built for riders who want to go far and go fast. The super powerful Bosch Performance Speed motor that assists up to 28 mph and extra long-lasting battery are perfect for long-distance commuters and avid e-bike riders. It also has thoughtful design features created specifically for people who prefer riding their bike over driving their car. And, your smartphone doubles as your controller, so you can use it for directions, music, and more.Domane+ LT is a carbon drop-bar electric bike designed for roadies who want an authentic road bike experience with an extra boost. The sleek and efficient Fazua drive system kicks things up a notch when you need it—like riding into a headwind or beating your buddy up a climb—but doesn't drag or hold you back when it's not in use.Verve+ 3 Lowstep is an electric hybrid bike that gives your daily cruises, commutes, and workouts a boost. The Bosch pedal-assist system is powerful and reliable, and the battery is fully encased in the frame for great looks and better balance. Plus, you don't need any tools to remove it! This e-bike comes equipped with parts that put your comfort and safety first, like a road-smoothing suspension seatpost, wide, stable tires, and front and rear lights.Allant+ 7S is a performance e-bike built for riders and commuters who want a fast, stylish e-bike with the added road-smoothing benefits of a suspension fork. A super powerful Bosch Performance Speed motor that assists up to 28 mph, quality parts, and a wealth of thoughtful design details make this electric bike a smart solution for getting around town every day.
Tech specs
expand_more
Frameset
FrameHigh-performance hydroformed alloy, Removable Integrated Battery, Range Boost compatible, internal cable routing, Motor Armor, post-mount disc, 135x5mm QR500 Series OCLV Carbon, Fazua Evation integrated drive system, tapered head tube, rear IsoSpeed, internal routing, flat mount disc, fender mounts, 148x12mm thru axleSizes: XS, S, M, L
Alpha Smooth Aluminum, with Removable Integrated Battery (RIB), Range Boost compatible
Sizes: XS, S, M, L
Sizes: M, L, XL
High-performance hydroformed alloy, Removable Integrated Battery, Range Boost-compatible, internal cable routing, Motor Armour, post-mount disc, 135x5 mm QR
Sizes: M, L, XL
NA
ForkAllant+ rigid alloy fork, 1-1/8" steel steerer, 100x15mm thru-axle, post-mount disc brakeDomane SL carbon, tapered carbon steerer, internal brake routing, fender mounts, flat mount disc, 12x100mm thru axleSizes: XS, S, M, L
Alloy rigid fork, 1-1/8'' steel steerer, 460mm axle-crown length (suspension corrected), ThruSkew 5mm QR
Sizes: XS, S, M, L
Verve Alloy, threaded steel steerer, rack mounts, post mount disc, 460mm axle-to-crown, ThruSkew 5mm QR
SR Suntour Mobie25, 45mm travel, preload, rebound and lockout, tapered alloy steerer, post mount disc
Accessories
BatteryBosch PowerTube 625Bosch PowerTube 500Bosch PowerTube 500
ControllerBosch SmartphoneHubBosch PurionBosch Purion
MotorBosch Performance Speed (28 mph), 250 Watt, 75NmBosch Active Plus, 250 watt, 50 Nm, 20mph or 32km/hBosch Performance Speed, 75 Nm, 28 mph / 45 kph
LightSizes: XS, S, M, L
Spanninga SOLO for e-bike
Sizes: XS, S, M, L
Herrmans H-Black MR4-E, 40Lux/120 lumen
Sizes: M, L, XL
AXA Blueline taillight
Sizes: M, L, XL
Herrmans MR8e, 180 lumen, 60 lux
Sizes: M, L, XL
Herrmans MR8
KickstandAdjustable length rear mount alloy kickstandRear mount, alloy
Wheels
Front hubBontrager sealed bearing, 32-hole 15mm alloy thru-axleFormula DC-20, alloy, 6-bolt, 5x100mm QRBontrager Disc, 32-hole, 6-bolt disc, 15mm alloy thru-axle
Rear hubBontrager sealed cartridge bearing rear hub, 32-hole, 6-bolt disc, 5mm QRFormula DC-22, alloy, 6-bolt, Shimano 8/9/10 freehub, 135x5mm QRBontrager alloy, sealed bearing, 6-bolt, 135x5mm QR
RimsAlex MD35 27.5", Tubeless Ready, 32-hole, 35mm width, presta valve
TiresBontrager E6 Hard-Case Lite, reflective, wire bead, 60tpi, 27.5x2.4"
Front WheelDT Swiss G1800, tubeless compatible, 100x12mm thru axle
Rear WheelDT Swiss G1800, tubeless compatible, 148x12mm thru axle
Front SkewerBontrager Switch thru axle, removable lever
Rear SkewerBontrager Switch thru axle, removable lever135x5mm bolt-on135x5mm bolt-on
RimBontrager Connection, alloy, double-wall, 32-hole, schrader valveAlex MD35, tubeless compatible, 32-hole, 35mm width, presta valve
Spokes14g stainless steelSizes: M, L, XL
J-Bend, 14g, Steel, Black
Sizes: M, L, XL
DT Swiss 14g, black
TireBontrager R3 Hard-Case Lite, Tubeless Ready, aramid bead, 120 tpi, 700x32cBontrager E6 Hard-Case Lite, reflective, wire bead, 60tpi, 700x50cSchwalbe G-One, 650Bx57c
Max tire size38c700x50c with or without fenders
Components
SaddleBontrager Commuter Comp, 185mm widthSizes: 50, 52, 54, 56, 58, 60, 62
Bontrager Arvada Comp, steel rails, 138mm width
Bontrager Arvada Elite, stainless steel rails, 138mm width
Bontrager BoulevardBontrager Commuter Comp
SeatpostBontrager Comp, 6061 alloy, 31.6mm, 8mm offsetSizes: 50, 52, 54, 56
Bontrager carbon internal seatmast cap, integrated light mount, 20mm offset, short length
Sizes: 58, 60, 62
Bontrager carbon internal seatmast cap, integrated light mount, 20mm offset, tall length
Comfort suspension, 31.6mmBontrager Comp, 6061 alloy, 31.6mm, 8mm offset, 330mm length
HandlebarBontrager alloy, 31.8mm, 15mm riseSizes: 50, 52
Bontrager Elite IsoZone VR-CF, alloy, 31.8mm, internal Di2 routing, 93mm reach, 123mm drop, 40cm width
Sizes: 54, 56
Bontrager Elite IsoZone VR-CF, alloy, 31.8mm, internal Di2 routing, 93mm reach, 123mm drop, 42cm width
Sizes: 58, 60, 62
Bontrager Elite IsoZone VR-CF, alloy, 31.8mm, internal Di2 routing, 93mm reach, 123mm drop, 44cm width
Sizes: XS, S, M
Bontrager alloy, 31.8mm, comfort sweep, 620mm width
Sizes: L
Bontrager alloy, 31.8mm, comfort sweep, 660mm width
Sizes: M
Bontrager alloy, 31.8mm, 15mm rise, 600mm width
Sizes: L, XL
Bontrager alloy, 31.8mm, 15mm rise, 660mm width
GripsBontrager Satellite Elite, alloy lock-onBontrager Satellite Elite, alloy lock-onBontrager Satellite Elite, alloy lock-on
StemBontrager alloy, 31.8mm, Blendr compatible, 7 degreeSizes: 50
Bontrager Pro, 31.8mm, Blendr compatible, 7 degree, 80mm length
Sizes: 52, 54
Bontrager Pro, 31.8mm, Blendr compatible, 7 degree, 90mm length
Sizes: 56, 58
Bontrager Pro, 31.8mm, Blendr compatible, 7 degree, 100mm length
Sizes: 60, 62
Bontrager Pro, 31.8mm, Blendr compatible, 7 degree, 110mm length
Sizes: XS, S, M
Bontrager alloy, 31.8mm clamp, adjustable rise, Blendr compatible, 85mm length
Sizes: XS, S
Bontrager alloy quill, 31.8mm clamp, adjustable rise, Blendr compatible, 85mm length
Sizes: M, L
Bontrager alloy quill, 31.8mm clamp, adjustable rise, Blendr compatible, 105mm length
Sizes: L
Bontrager alloy, 31.8mm clamp, adjustable rise, Blendr compatible, 105mm length
Sizes: M
Bontrager alloy, 31.8mm, Blendr compatible, 7 degree, 70mm length
Sizes: L
Bontrager alloy, 31.8mm, Blendr compatible, 7 degree, 90mm length
Sizes: XL
Bontrager alloy, 31.8mm, Blendr compatible, 7 degree, 100mm length
Sizes: XL
Bontrager alloy, 31.8mm clamp, Blendr compatible, 7 degree, 100mm length
HeadsetFSA IS-2 alloy, integrated, sealed cartridge bearing, 1-1/8" top, 1.5" bottomSizes: XS, S, M, L
VP sealed cartridge, 1-1/8'', threaded
Sizes: S, M, L
1-1/8'' threadless, sealed cartridge bearings
FSA Integrated, sealed cartridge bearing, 1-1/8'' top, 1.5'' bottom
BrakesetShimano MT520 4-piston hydraulic disc, post-mount 180mm rotor
Handlebar TapeBontrager Supertack Perf tape
BrakeShimano Ultegra hydraulic disc, flat mountShimano MT200 hydraulic discShimano MT520 4-piston hydraulic disc, post-mount 180mm rotor
Brake RotorSizes: 50, 52, 54, 56, 58, 60, 62
Shimano MT800, centerlock, 160mm
Shimano EM810, centerlock 160mm
Shimano RT26, 6-bolt,160mmShimano RT26, 6-bolt,180mm
Drivetrain
ShiftersShimano Deore M4100, 10 speed
Rear derailleurShimano Deore M5120, long cageShimano Ultegra R8000, long cage, 34T max cogShimano Alivio T4000, long cageShimano Alivio T4000, long cage
CrankProWheel 46T narrow/wide steel, w/alloy guardSizes: 50, 52
FSA Alloy for Fazua, 50/34 chainrings, 170mm length
Sizes: 54, 56
FSA Alloy for Fazua, 50/34 chainrings, 172.5mm length
Sizes: 58, 60, 62
FSA Alloy for Fazua, 50/34 chainrings, 175mm length
Prowheel alloy, 38T steel ring, 170mm lengthSizes: M
ProWheel alloy, 170mm
Sizes: L, XL
ProWheel alloy, 175mm
CassetteShimano Deore M4100, 11-42, 10 speedShimano Ultegra HG800-11, 11-34, 11 speedShimano HG200, 11-36, 9 speedShimano HG200, 11-36, 9 speed
ChainKMC E10Shimano Ultegra HG701, 11-speedKMC X9KMC X9
PedalsBontrager Satellite City pedal
ShifterShimano Ultegra R8020, 11-speedSizes: XS, S, M, L
Shimano Alivio M3100, 9 speed
Sizes: XS, S, M, L
Shimano Alivio M4000, 9 speed
Sizes: M, L, XL
Sizes: M, L, XL
Front DerailleurShimano Ultegra R8000, braze-on
PedalSizes: XS, S, M, L
Bontrager City pedals
Sizes: XS, S, M, L
Wellgo C157, boron axle, plastic body
Weight
WeightM - 25.58 kg / 56.4 lbs32.3 lbs / 14.7 kg with drivepack, 26 lbs / 11.8 kg without drivepack (including storage cover, sold separately)M - 54.61 lbs / 24.77 kgM - 24.52 kg / 54.06 lbs
Weight limitThis bike has a maximum total weight limit (combined weight of bicycle, rider, and cargo) of 300 pounds (136 kg).This bike has a maximum total weight limit (combined weight of bicycle, rider, and cargo) of 275 pounds (125 kg).This bike has a maximum total weight limit (combined weight of bicycle, rider, and cargo) of 300 pounds (136 kg).This bike has a maximum total weight limit (combined weight of bicycle, rider, and cargo) of 300 pounds (136 kg).
Why you'll love it
expand_less
arrow_backContinue shopping
CANNONDALE
Cannondale Tesoro Neo X 3 Remixte Electric Bike - 2021Cannondale Quick Neo SL 2 Remixte Electric BikeCannondale Tesoro Neo X 2 Electric BikeCannondale Topstone Neo Carbon 2 Speed Electric Bike - 2021
$3,350.00$2,550.00$4,100.00$7,200.00
Shop ItemShop ItemShop ItemShop Item
RemoveRemoveRemoveRemove
Reviews
(0)0 reviews
(3)3 reviews with an average rating of 3.7 out of 5 stars
(2)2 reviews with an average rating of 3.0 out of 5 stars
(2)2 reviews with an average rating of 5.0 out of 5 stars
Hide
Best UseUrban Cycling, Bike TouringRecreational CyclingBike Touring, Urban CyclingRoad CyclingHide
E-Bike ClassificationClass 3: pedal assist up to 28 mphClass 1: pedal assist up to 20 mphClass 3: pedal assist up to 28 mphClass 3: pedal assist up to 28 mphHide
MotorBosch Performance Line Sport 250WMAHLE ebikemotion X35 250WBosch Performance Line Speed 250W (28mph)Bosch Performance Line Speed 250WHide
Motor TypeMid-DriveGeared HubMid-DriveMid-DriveHide
Motor Torque (Nm)50 Newton meters40 Newton meters65 Newton meters85 Newton metersHide
Battery TypeLithium IonLithium IonLithium IonLithium IonHide
Battery Capacity (Wh)500 watt hours250 watt hours500 watt hours500 watt hoursHide
Battery RemovableYesNoYesYesHide
Charge Time (hrs)3.5 hours3 hours4.5 hours3.5 hoursHide
Pedal Assist Range104 miles40 miles52 miles75 milesHide
Bike Frame MaterialAluminumAluminumAluminumCarbonHide
FrameRemixte SmartForm C2 Alloy, tapered head tube, internal cable routingQuick Neo SLSmartForm C1 Alloy, dual battery ready, post-mount discBallisTec Carbon Frame, removable downtube battery, Kingpin suspension system, 12 x 148 thru axle, dropper post compatibleHide
Step-ThroughYesYesNoNoHide
Bike SuspensionFront SuspensionNo SuspensionFront SuspensionRear SuspensionHide
ForkSR Suntour XCM ATB, 100 mm, Coil, 46 mm offsetQuick Neo SL, carbonSR Suntour XCM 34 Boost, 100mm, Coil, 46mm offset1-1/8 to 1-1/4 in. tapered steerer, 55 mm OutFront offset, flat mount disc, internal routing, 12 x 110 mm thru axleHide
Fork Travel100 millimeters100 millimetersHide
CranksetFSA Bosch E-Bike, 46TProwheel alloy, 38tFSA Bosch E-Bike with custom Ai offset, 46TFSA Bosch E-Bike, 48/32THide
Bottom BracketCartridge, square taperHide
Shifters9-speedShimano Altus, 9-speedShimano Deore M5100, 11-speedShimano GRX 800, 2 x 11Hide
Front DerailleurShimano GRX, braze-onHide
Rear DerailleurShimano AlivioShimano AltusShimano Deore M5100Shimano GRX 810, Shadow RD+Hide
Rear CogsShimano HG200 11-36T, 9-speedShimano HG201, 9-speed, 11-36tShimano Deore 5100, 11-51T, 11-speedShimano 105, 11-34T, 11-speedHide
Number of Gears9 gear(s)9 gear(s)11 gear(s)22 gear(s)Hide
Brake TypeHydraulic Disc BrakeHydraulic Disc BrakeHydraulic Disc BrakeHydraulic Disc BrakeHide
BrakesShimano MT200 hydraulic disc, 180/180 mm RT10 rotorsShimano MT201 hydro disc, 160/160mm RT26 rotorsShimano MT200 hydraulic disc, 180/180 mm RT30 rotorsShimano GRX hydraulic disc, 180/160 mm RT64 rotorsHide
Brake LeversShimano MT200 hydraulic discShimano MT201 hydro discShimano MT200 hydraulic discShimano GRX hydraulic discHide
RimsWTB STX i25 TCS, 32h, tubeless readyShining, 32hWTB STX i25 TCS, 32h, tubeless readyWTB KOM Light i23 TCS, 28h, tubeless readyHide
Front HubShimano TX55, quick-release axleFormula CRX-512, 12 x 100Shimano MT400 15 x 110mm thru axleFormula cartridge bearing, Centerlock, 12 x 110 mm thru axleHide
Rear HubShimano MT400 12 x 148 mm thru axleMAHLE ebikemotion X35 250WShimano MT400 12 x 148mm thru axleFormula cartridge bearing, Centerlock, 12 x 148 mm thru axleHide
Wheel Size29 inches700c29 inches700cHide
TiresSchwalbe G-One Allround Performance, 29 x 2.25 in., RaceGuard, tubeless readySchwalbe Energizer Plus, 700c x 38mm, GreenGuard, Addix-E compoundSchwalbe G-One Allround Performance, 29 x 2.25 in., RaceGuard, tubeless readyWTB Riddler TCS Light, 700c x 37 mm, tubeless readyHide
Tire Width2.25 inches38 millimeters2.25 inches37 millimetersHide
Handlebar ShapeRiser BarRiser BarRiser BarDrop BarHide
HandlebarCannondale 3, 6061 double-butted, 20 mm rise, 9 deg. back, 720 mmCannondale Riser, 6061 alloy, 18mm rise, 8° back, 4° up, 680mmCannondale 3 Riser, 6061 alloy, 15mm rise, 8° sweep, 4° rise, 740mmCannondale 3, butted 6061 alloy, 16 deg .flare dropHide
StemCannondale adjustable Aheadset, 31.8 mmCannondale 3 with Intellimount, alloy, 31.8mm clampCannondale Adjustable , A-headset, 31.8mmCannondale, 6061 alloy, 31.8 mm, 7 deg.Hide
Seat PostCannondale Ergo Touring6061 alloy, 31.6 x 350mmCannondale Ergo TouringPromax SP-9032, Carbon, 27.2 mmHide
SaddleCannondale 4, 6061 alloy, 31.6 mmCannondale Fitness Ergo Double DensityCannondale 4, 6061 alloy, 31.6Fizik New Aliante R3, 150 mm width, K:ium railsHide
PedalsCannondale platformCannondale UrbanCannondale FitnessNot includedHide
HeadsetIntegrated sealed bearing, taperedFSA sealed bearing, integrated, 1 1/4 to 1 1/8 in.Integrated sealed bearing, taperedIntegrated, 1-1/2 to 1-1/8 in. tapered with reducer, 25 mm alloy top capHide
ChainShimano HG93, 9-speedKMC E9T, 9-speedShimano HG601, 11-speedShimano HG701, 11-speedHide
WeightUnavailable33 lbs. 8 oz.55 lbs. 9.6 oz.36 lbs. 14.4 oz.Hide
Bike WeightBike weight is based on median size, as sold, or the average of two median sizes.Bike weight is based on median size, as sold, or the average of two median sizes.Bike weight is based on median size, as sold, or the average of two median sizes.Bike weight is based on median size, as sold, or the average of two median sizes.Hide
GenderUnisexUnisexUnisexUnisexHide
I thought I would add the Giant Products. I understand this is the top-selling manufacturer in the world. But I may be wrong.
Recommended Retail Price$3,500$3,900$2,000
HYBRID CYCLING TECHNOLOGY
MotorGiant SyncDrive Pro, 360% tuneable support, powered by YAMAHA. Pedal support up to 28 mph.Giant SyncDrive ProGiant SyncDrive Life, 300% tuneable support, 5-mode plus Automatic mode, 60Nm, 20MPH max. assist, powered by YAMAHA
SensorsGiant PedalPlus 6-sensor technologyGiant PedalPlus 6-sensor technology
DisplayGiant RideControl EVOGiant RideDash EVOGiant RideControl One
BatteryGiant EnergyPak Smart 375, 36V Integrated Lithium-IonGiant EnergyPak Smart Compact 500WhEnergyPak 400Wh
ControllerGiant RideControl Ergo
FRAME
SizesXS, S, M, ML, L, XLXS, S, M, ML, L, XLS,M,L
ColorsBlack / BlackBlackRoyal Blue, Seafoam Green
FrameALUXX SL aluminumALUXX SL aluminumALUXX Aluminum, double tube low-stepthrough design
ForkALUXX SL-grade aluminium, 12x100 thru-axleALUXX SL-grade Aluminium, 12x100 thru-axleALUXX Aluminum
COMPONENTS
HandlebarGiant Connect XC Riser 31.8 x 690mmGiant Connect XC Riser 31.8 x 690mmAluminum 30 degree sweep
StemGiant ContactGiant ContactAluminum angle adjustable 1 1/8" x 85mm
SeatpostGiant D-shape, AluminiumGiant D-shape, AluminiumAluminum
SaddleGiant SportGiant SportGiant Comfort
PedalsAluminum PlatformAluminum PlatformAnti-Slip
DRIVETRAIN
ShiftersShimano Tiagra, 10-SpeedShimano Tiagra, 10-Speed8 Speed trigger
Front Derailleur--N/A
Rear DerailleurShimano GRX RX400Shimano GRX RX400Shimano RD-M310 Altus
BrakesShimano BR-MT200, hydraulic disc, 180/160mmShimano BR-MT200, hydraulic disc, 180/160mmTektro HD-M275 Hydraulic Disc
Brake LeversShimano BL-MT201Shimano BL-MT201Tektro HD-M275 Hydraulic Disc
CassetteShimano Tiagra, 11-36, 10-SpeedShimano Tiagra, 11-36, 10-SpeedShimano HG-200 12-32T
ChainKMC e.10 SportKMC e.10 SportKMC X8 NP/NP
CranksetForged Alloy minimal Q-factor, 42TForged Alloy minimal Q-factor, 42TGiant Aluminum 38T
WHEELS
RimsGiant eX-2, Tubeless ReadyGiant eX-2, Tubeless ReadyGiant CR70 Double Wall Aluminum 559x19
HubsGiant Performance Tracker Road, Sealed BearingGiant Performance Tracker Road, Sealed BearingGiant Tracker Sport Disc
SpokesStainlessSapim E-Lite [r] Race [f]Stainless Steel
TiresKenda Kwick Seven.5 27.5 x 2.40 (61-584), 60TPI, w/ reflexKenda Kwick Seven.5 27.5 x 2.40 (61-584), 60TPI, w/ reflexCST Metroplolitan Palm Bay 60-559 (26")
ExtrasGiant EnergyPak 6A fast chargerGiant EnergyPak 6A Smart Charger, Giant EnergyPak Plus range extender compatibleGiant EnergyPak 3A Charger, Giant Direct Mount KSA18 Trekking Kickstand
ACCESSORIES
LightingAxa BlueLine 50 frontAxa Blueline rearAxa BlueLine 50 frontAxa Blueline rear
CarrierGiant Rack-It MIKGiant Rack-It MIKAluminum rear rack for carrier mount battery
TECHS & FEATURES
ALUXX SL Aluminum Technology
Hybrid Cycling Technology
RideControl EVO
SyncDrive Pro
Smart Assist
D-Fuse Technology
RideControl Ergo
RideDash Evo
Energypak
ALUXX Aluminum Technology
SyncDrive Life
RideControl ONE
