Bike Air Shocks
flugelboneman
Canada
Comox Valley British Columbia Canada
Explorer +1. Checked the air in shocks and it all came out when checking. All air came out. How much pressure for Forks? Do u have to use a hand pump?
Air shocks are high pressure, low volume. Air will escape in a split second with a standard pump or gauge. Whether a screw on or clamp on pump, both will allow too much air to escape. I find my RockShox rarely require air, but I had to purchase an air shock pump with gauge. If the bike didn't come with a fork manual, check the fork manufacturer's website.
This is the pump I purchased, works great.
RockShox High-Pressure Shock Pump (300 psi max) https://www.amazon.com/dp/B005543YUE/ref=cm_sw_r_cp_apa_i_N4ksDb29J1G2B
Thx for reply and insight. I will stop in at my bike shop and let them wrestle with it. I tried to put air in but, as you say, it escaped as soon as I disconnected the pump.
