PJungnitsch
I had a misadventure repairing the charger for my Biktrix Juggernaut, it shorted briefly once plugged in, as noted here:
https://electricbikereview.com/forums/threads/connectors-and-the-cycle-satiator.10853/
The battery ran the bike after, and there is full voltage on the output plus the battery indicator shows (a small amount) of charge. But I can't measure voltage on the charging port, and when plugged in the charger will not activate. Got a new charger but it acts the same way, assume it won't go into charge mode without sensing voltage.
Took the case apart, and the fuse looks good, as does all the wiring. The battery pack looks like it was made with care:
Would disconnecting the white connector in the picture have a chance at rebooting the battery management system?
