Mike leroy
Are carbon bikes are a viable option with 750W, 120Nm motor?
I plan to carry 50 pounds of food up a hill that varies from 7% to 18% grade for 1.5 miles.
I weigh 175 pounds. I currently run up this hill with 10 pounds of food in a fanny pack. I do not own a bike, so I do not know whether I generate 100W or 200W of pedal power.
Any concerns with the Felt NINE 3? I am starting with it as a reference point, because it is easy to compare to the Felt NINEe 20, which is not powerful enough.
- Frame:
Felt XC, UHC Performance carbon fiber, MMC w/ InsideOut construction, full carbon dropouts, ControlTaper head tube, Kevlar chain watcher, replaceable derailleur hanger, 140mm post disc mounts , standard 73mm threaded bottom bracket, 12 x 142mm Syntace style through axle, internal derailleur cable routing, Ø27.2mm seatpost, Ø34.9mm high clamp front derailleur mount
- Bottom Bracket:
Shimano sealed threaded
- Bottom Bracket:
