Hey guys and gals,
I bought a used Watseka e-bike 36v 250w 9ah battery color is black.
Checked it out with a Romai controller tester and it showed it needed a new controller.
Tested motor and Hall Effects Sensorsthey tested as they should as well as did the main phase .
Tested new controller and it passed with flying colors.
Tested twist throttle shows to be work according to Ronai tester.
Battery shows 38.5v.
I replaced the controller hooked it up to battery.
Turned throttle all the way open and rear bike wheel turns but pulses, lets say ever second or second and a half.
if I back off on the throttle and slowly advance the throttle it will slowly pick up momentum and I can then s l o w l y advance the throttle and the motor will pick up speed till the motor reaches top speed.
Once back tire is spinning at a good rate I can go on and off throttle no pulsing no hesitation.
If it was an old school car I'd say it has a sticky choke or maybe trying to vapor lock or weak fuel pump but alas, it's electric and not a gas engine.
Wonder what is causing it to pulse when I open the throttle up to the maximum when starting out from a dead stop.
Why does it work if I slowly twist the throttle feathering the power from no throttle to max throttle?
Things that make me say hmmm?
Thanks
Joe in Florida.
Thanks
Joe in Florida.
Watseka XP Review | ElectricBikeReview.com
Price: $649.00 | Model Year: 2016 | An ultra affordable electric bike sold on Amazon for ~$650, requires 1.5+ hours for assembly along with some basic tools (it comes with a few unique wrenches and instructions to get you going), the kickstand is two-sided and very stable which helps with setup
electricbikereview.com
