How do you set max speed for each assist levels? Thanks
tomjasz Well-Known Member Region USA City Minnesnowta Sep 10, 2020 #2 Gr3 said: How do you set max speed for each assist levels? Thanks Click to expand... Is this a BBSxx series motor? If yes, you'll need a programming cable.
tomjasz Well-Known Member Region USA City Minnesnowta Sep 10, 2020 #4 Gr3 said: How do you know? It is a bafang 500w rear hub. Click to expand... I'm not familiar with all hub motor controller programming. Most lower-end hub kits don't have programmable controllers. But I'm not qualified to help here. BBsxx series is the strongest in my knowledge base. Sorry.
A AHicks Well-Known Member Region USA City Snow Bird - Summer S.E. Michigan, Winter Gulf Coast North Central Fl. Sep 21, 2020 #5 Gr3 said: How do you set max speed for each assist levels? Thanks Click to expand... Without knowing what controller you have, it's nearly impossible to know if you can, or how that might be done (if it's even possible).
