Connect throttle to controller on a Nero blue e bike, how do you get to the controller in the frame
mickwill
United Kingdom
How do you get to the controller on a Nero blue e bike to connect the throttle that in the frame above the battery
"Start" by removing the battery. Then, depending on the bike, you should be able to see the controller cover that's generally held in place with several screws.
Hi Did you manage to get the controller out ok ? And if so was it faulty ? And where did you find replacement? Thanks
