Magnus Branzén
I'm about to buy my second electric bike, an Evo Cross 2014 model. In several european countries, the motor has been restricted to 250 watt from the default 350 watt.
I hope there are actual benefits to the systems lifespan and range from the battery with the restriction, besides making it street legal. Or does the modification necessary to restrict power output in itself cause increased wear and tear?
The question perhaps should be put how is the restriction accomplished: via modification to the battery, to the the control box, or in the hub motor? And how?
(As an aside: A mini-PC I own that essentially doesn't have good enough cooling for the chassi size and thermal output, I've restricted the processor in software to stay below about 70 % of max. The system performs much better thermally now – the fan can stay in lower RPM. 250 watt from a 350 watt motor is also around 70 %...)
