One owner, black, 1850 miles, 100% battery life still remaining, New front 46t sprocket, new chain, new cog set, almost new Electrik 2.0 Armadillo Gripton has the smooth tread similar to the Como and original Trigger tires will be included. Upgraded 200mm rotors front and back, original brake pads still good, Handlebars with a small amount of rise were installed. Original seat. Original pedals. Never dropped, never in the wet or washed.
Local bike store is Specialized dealer and they can ship via Bikeflights from zip 66049 and they can also do an inspection coordinated through purchaser.
$3000 for a bike that cost over $5k new plus upgrades. I'll post some pictures shortly and add info as asked or if it is deemed helpful. The front chain ring was changed from a 52t to a 46t in part because the cog set doesn't have the larger rings, it is more compact and it was sitting on the shelf. So if you desire some hill climbing gearing you will want to change some of the rear cogs or complete set but the 46t will be helpful in that department. This drivetrain was changed and hardly ridden since because of a Como I also own.
And if there any changes the buyer needs the lbs is good to work with a very capable of making changes to be coordinated through purchaser.
