Bosch Drive Unit Service Kit - Maintenance BDU2XX
Dima
In the end, all that’s left -emotions and feelings
Europe
Minsk
I need some help ! i bought a used bike ! and i have found a repair Bosch Drive Unit Service Kit - Maintenance BDU2XX but ! it is for Bosch Performance Line CX 2016 - 2019 . I googled ! the same models as mine exist in 2020 ( they look ) the same ! but what about my bike ? is it 2020 , 2019 , 2018 ? Is it Nevo 3 , 4 , 5 ?
Thank you ! first photo - is mine , the second 2020 ( from internet )
My number is 0275007037
I am not sure ? which exact model ! your bike is ! ? !! But it definitely ! fits your motor ! If that is ? What you want ! to know ? !
my - dual batteries ( some people say it does not fit) !
So you want to know if the Service Kit fits your motor even though you have dual battery?
And some people say that does not fit? You read that on facebook?
Some people also say the earth is flat (which would be great for bicycling 😆 )
Does the motor make noise? Does it feel rough? If yes, go ahead and install the new parts from that service kit. It comes with instructions and it is easy done with the right tools.
i should choose the RIGHT kit ( and for my bike ! and i am trying to get the year of production of my model ) to choose the RIGHT kit!
also i am going to start Expedition Touring ( 10 countries - 13000 km ) so better to know that engine is perfect
Your motor is a BDU2XX. There is only one kit for any of the BDU2XX motors (except the ones with coaster brake, which yours does not have).
So this kit is the right kit for your motor.
are you 100% sure ?
Ehat he sa
The R&M model year of your bike is irrelevant if you already know your drive unit part number. You have the right kit.
are you 100% sure ?
If you are 100% sure the pictures and part numbers you posted are correct, then yes Wildtrak knows his stuff.
Ehat he sa
Thank you!
Yes. I installed that multiple times already.
did you use this kits
Or maybe i need lesser equipped kit to do kind of " regular service ?"
Ehat he sa
www.ebike24.com
Bosch Drive Unit Service Kit - Maintenance BDU2XX​
The Bosch Drive Unit Service Kit Repair BDU2xx is a spare parts kit for repairing Active Line and Performance Line drives from model year 2014.…
www.ebikemotorcentre.com
Bosch Gen 2 Motor Overhaul Bearing Kit PLB00701​
This Bosch Gen 2 Motor Overhaul Bearing Kit PLB00701 includes every bearing required for the motor gears and drive train, plus two crankshaft O-rings
Depends on the condition of your motor. Maybe you do not need it at all.
I have one of those motors with over 30.000km on it. Never opened and it still runs smoothly.
i dont hear any noise ) and the total range is about 8500 . ! But i want to start expedition ) from 6000km to 13000 km ) a bit risky ! )) i need either spare motor ( to be delivered somewhere when 8000km will be done ) or i should trust my motor on 100 % :)
@Dima I haven't rebuilt anything in my drive unit or added/replaced the o-rings to help block water intrusion. I have about 22000 km on the bike with a fair bit of that in rainy conditions. It's a little noisier/rougher than it was on day 1, but still chugs along just fine.
Please take a look on this numbers in the end ( does it only mean the difference in complication ( expanded and not ) i mean bearings the same for my engine ?
Go with the Service Kit, not the bearing set.
You will need special tools to replace the motor or the service kit.
Also, the spare motor should be configured right if you get one and your bike has the Rohloff or Enviolo. Cannot see that on the picture.
Here is what I would do:
Get a spare motor, make sure it is configured correctly. Leave it at a friends place and have it shipped in case you need it.​
or​
Bring the Service Kit and tools on the trip. Make sure you know how to install it. It is not that easy if you do it for the first time.​
I would go with the latter option and start the trip with the motor as is. Make sure you have the right tools. There are youtube videos about how to install the service kit.
I have seen another guy going all the way to Asia, over 80.000km with no Gen 2 motor issues.
BTW, I have a spare motor in my trailer to give it an extra boot on steep uphills :D
or​
what a beautiful set ! Do you have an instagram ? ) Join me "Across the Caspian SEA" ))))))) this is my idea !)
Get a spare motor, make sure it is configured correctly. Leave it at a friends place and have it shipped in case you need it - agree ! Or make complete overhaul ! ( all bearing ) before the trip !​
or​
ver 80.000km with no Gen 2 motor issues. !!! 80.000km no Gen 2 motor issues!! UNBELIVABLE!
